Redline Non Slip CVT Fluid
Prius “CVT” should use WS, not CVT fluid.
The transaxle on those are bulletproof and are unlikely to be a reliability issue…even if you never replaced the fluid.
I bought car with 170 thousand miles have about 212000 miles on it it… have changed transmission fluid 3 times-yea know it’s overkill but not too expensive… have used Redline d6. Knocking on wood that have not seen any major oil consumption or anything… I drive a lot usually use pump to evacuate at about 5000 miles then have fluid drained and filled after another 5000 miles-use purolator boss-although usually fram ultra available at Walmart
