Originally Posted By: ARCOgraphite
Originally Posted By: gib
Originally Posted By: Colt45ws
Dirt ingress tripled over the same time frame, AND it was changed back to a paper?
... There's a lot of silicon in this sample and that's probably why the iron wear increased. He did change to a paper filter, but after ~9k miles on the K&N I suspect the "damage" was done. ...
Changing a filter is prime time for dirt ingestion. No matter how carefull and fastideous you are a fair amout of dirt will be loosened up from around filter gasket and intake tubing and set up to migrate back into the intake. You cant avoid it.
I've never seen more then a few ppm increase in silicon between air filter changes. I'm very anal about it and will vacuum clean the air box before installing a few filter.
Aftermarket intake systems are even easier... Remove the cone air filter, wash and reinstall. (Or put a new one on)
Not much chance in dirt getting in the tube.
