Redesign for barebones Raspberry Pi computer
PA
From BBC:
A new version of the Raspberry Pi barebones computer has been released.
Called the B+, the updated version uses less power than its predecessors and will cost about $35 (£20).
The B+ can also power more peripherals without the need for a dedicated power source and has more connectors to help link it to other devices.
The new model is released as the Pi faces increasing competition from other tiny computers.
Power train
The B+ is based on the same Broadcom chip as earlier versions and has the same 512 megabytes of memory but a variety of other changes have been made to the device.
The analogue and composite video connector has been ditched in favour of a single four-pole connector and the SD card slot has been replaced with a micro-SD card unit. This has a latch on it to ensure the smaller card does not fall out.
Better power management on the B+ will mean it can keep four USB peripherals going without requiring mains power or an external hub.
"People expect to see four USB ports these days," said Mike Powell, a spokesman for electronics components firm Element 14 which sells the Pi. "With the Model B as soon as you had connected a keyboard and mouse that was it."
More USB ports and better power management allowed owners to run a 2.5in (6.4cm) hard drive off the device without the need for a powered hub, said Mr Powell.
The General Purpose I/O (GPIO) section of the device has also been expanded to 40 pins - 14 more than on the original machine.
This, said Mr Powell would give people many more options to add work with extras such as sensors and relays.
"When the Pi was first launched they really underestimated what people were going to do with it," he said.
Close-up of Raspberry Pi Model B+ About three million Raspberry Pi computers have been sold around the world
In a review of the B+ in Linux Voice Ben Everard said one of the most significant improvements was the gadget's power management. An improved voltage regulator meant the device was much more stable when handling USB-connected peripherals.
"To be able to handle lots more input and output means this is a significantly more useful computer," wrote Mr Everard, "and will be especially important for new users who may not have a great power supply or a powered USB hub."
The B+ will be available via online electronics stores such as Element 14. About three million Raspberry Pi computers have been sold around the world.
The Pi now faces much more competition from devices such as the Beaglebone Black, the Hummingboard, the APC 8750, the Android MK802 mini PC, Banana Pi and the Matrix TBS2910.
http://www.bbc.com/news/technology-28263659
"... in favour of a single four-pole connector ..." Does that mean HDMI?
The circuit board has HDMI printed on it:
Nah, the HDMI is digital and staying. They got rid of the Yellow Composite (RCA jack) connector. They designed the original to be able to be used with almost any kind of display, even cheap old TVs that don't have HDMI.
I thought that I would chime in on using the Raspberry Pi. The features on the B+ makes it a little more user friendly, while keeping the price at $35.
I have a RPi model B that I have had in continuous use for more than a year. I run it as a headless file server with 2 - 2tb drives attached. This is used for auto file backups, as a DLNA media server, and as an automatic scheduled radio stream recorder.
It is amazing to me to see what can be done with a cheap computer the size of a deck of cards. There is a vast array of information online with many project ideas. I don't think that I am much of a computer geek, but it is fun to play with and to learn a little bit of linux.
