Originally Posted by dave1251
Originally Posted by 69Torino
Breaking in a flat tappet cam is much different than maintaining a broken in flat tappet cam. Different formulas are required for each, the latter being much more forgiving. I run my 1947 Ford Tractor on SN oils with zero issue. I've also ran many old iron Ford V8's on regular Valvoline white bottle and Castrol GTX with no issue. The cams were broken in correctly though.
I agree with you but there has been a decade of shady tree mechanics spreading thier bunk while receiving revenue from additive companies and blenders for zenk. This is even for cars with engines built in the 60's when the spec oil was a group I with about 200-600PPM of ZDDP. Some how ZDDP 600 to 800 PPM in a blend is not enough "zenk".
This would explain my success with "run of the mill" oils in moderately powerful Ford V8's over the years. When I was young, I barely had the money to put an engine together, let alone spend $60-$70 on an oil change. Hence my junk got off the shelf oil. Never lost a cam.
I am in a better position financially than I was in my teens and twenties now, so I can spring for the break in oil, and the fancy feel good oil after break in, but as proven in my younger years it's not a necessity. When I was young I thought VR-1 was expensive!
To the OP, I believe VR-1 to be the best possible option, it has the specs and the reputation, plus I'm a big fan of Valvoline. They are after all, the inventor of "motor oil", as it were. Not trying to persuade or dissuade, I have also had great results with Castrol GTX 20W-50, I have used it in my tractor once, and have a video of the tractor starting at -12F with 20w-50 Castrol in the pan. It wasn't pretty but it did start. My dad also used Castrol 20W-50 in the Torino that I now own. He raced that car all through the 70's and it survived, and it's still fast.
