Recommendation Needed... Short Trips and GDI Engine.
MA
My wife has a 2016 Mazda CX-5 with the 2.5L SkyActive GDI engine. She walks dogs for a living and is a full-time mom so she typically does many short trips per day, probably just a couple miles at a time. Enough to drive about 15k miles per year but many, many short trips.
The 2.5L SkyActive engine is also GDI and I believe is known for fuel dilution.
I usually change the oil every 5k but I've noticed lately it is black as ink and smells a bit like gasoline. Is there a specific brand oil that handles short trips and fuel dilution better than others? Thanks!
Answer: Higher viscosity oil.
If the automaker recommends a 20 weight move to a 30 weight preferably API SP. No oil can "handle" fuel dilution because we're talking about a low viscosity liquid, in this case gasoline, which is thinning the higher viscosity motor oil. In any case some fuel isn't going to be the end of the world and from used oil analysis I've seen as it appears that they all remain under the 5 percent range.
GDI will turn oil dark. They're like a diesel in that regard.
@BMWTurboDzl The engine has 130k on it now so I have thought about moving to a 0w30 from a 0W-20. I have also considered moving to a "Euro" spec oil as well to better deal with the contaminants.
I don't know what OCI or oil Mazda recommends but euro spec oils are designed for long drain intervals (10k miles) so they would give you a lot of headroom on a 5k oci.
Factory says 7500 miles but all of the dealerships I've seen seem to be leaning towards the 5K range. My Stealership is $130 to do that full synthetic change. Guess who is still doing their own OCI's for under $35 a change.
I would substitute a qt of 10W30 (not 0W30 !) to your sump. You can run 5W20 in the warm months.
You don't want 0W anything unless you need it or if its a "real" synthetic. If you find a real synthetic** let me know,
I know Winter here, I live just a few miles up the road in NH
_________________________________________________________________
** majority group IV & V base stock
Valvoline because of high moly content. I don't think any off the shelf 5w30 has as much moly as valvoline (300+ ppm). At least that was my rationale with Turbo GDI
How does "high moly content" help an oil resist fuel dilution?
"The common type of moly that is used in today’s oil formulations is "Molybdenum Dialkyldithiocarbamate" (MoDTC). This form of moly is 100% oil-soluble - which means that it remains suspended in the motor oil and does not fall out of suspension.
Molybdenum Dialkyldithiocarbamate (MoDTC) is an organo-molybdenum compound. The oil-soluble moly’s are considered to be organo-metallic friction reducers. They also provide very effective oxidation resistance."
From : https://synlubepros.com/blog/posts/tips/moly-in-engine-oil
Fuel dilution increases oxidation. Moly not only reduces friction but lowers oil oxidation. Win - Win.
Does the engine get to temp after a few short trips? 15k is a good bit of mileage, any long trips?
Id want to pull a used oil analysis, and see what the fuel dilution is, and what it looks like degradation wise.
I think the easiest thing would be to move up to a 5w30 to combat fuel dilution (thinning of the oil mainly)
and use reasonable OCI's
in the winter 3mo/3000 miles might be appropriate.
rest of the year 6month/5000 miles?
UOA if you want.
Even with all the short trips it seems you must be getting it good and warmed up on a regular basis if you are putting on that many yearly miles.
