Recochem antifreeze?
ME
Have an almost empty jug of "VIP" store brand coolant. Bottom is stamped "recochem"; a web search pulls up a Canadian company that makes antifreeze. Am considering buying more.
Their website, http://www.recochem.com/ requires logging in to see MSDS sheets.
The jug, and website, list ethylene glycol as the main ingredient in the 2 year, 50k mi normal drain auto antifreeze I'm interested in. I want to know if phosphates are also in this brew: Saturn's S-series forbids phosphates.
If phosphates are in the ingredients, do they have to be on the label? I assume this stuff is safe to use unless my research decides otherwise. Their pdf says meets GM specs 1825M and 1899M but my cars just say "phosphate free ethylene glycol".
Most "simple green" products don't specifically state the presence of phosphates, either, but they're known to be loaded with the stuff, as well as silicone/silicates as their corrosion inhibitor package. I'd wager it's just one more traditional green "Prestone" clone. The two year/50,000 mile change interval is a mystery, though. (makes more sense if it were 50,000 kilometers, though...) GM's Dex-Cool spec is listed as, 6277, so we can rule that out. If your Saturn's cooling system is sensitive to traditional phosphated coolants, I wouldn't use this stuff in your Saturn if I were you.
Footnote on coolant/antifreeze MSDSs - I recently visited Peak's web site to check out the MSDS for their amber extended-life product. It listed percentages of "ethylene glycol", "water" (and their standardized CAS #s), and a percentage, generic, "corrosion inhibitors", listing, only. Apparently manufacturers are not required to list proprietary formulary information except in vagueries.
[ July 09, 2004, 02:09 PM: Message edited by: Ray H ]
