Reclaimed Oil for push mower.
Used oil is free fuel. And that is what you do by giving it to the auto parts store, it is mainly used to mix with bunker oil for ships etc. at least that was the case in years past. Used acidic dirty oil is not for lubrication.
Except it tests decent. Still have some tbn left. From what I can find oil ran in daily driver cars has to be ran at least 300hrs before it even gets close to turning acidic.
My reclaim oil is only ran for 90 to 120hrs.
Also its not dirty, after it's sat for a month I can't see any single micron particles under my microscope when i pull a sample. What i can see is a layer of dirt on the bottom of the jug when I pour out the last half quart into the combustion grade oil jug or my log soaking oil trough.
Price out a new lawn mower - good luck finding a good self propelled gas powered mower for under $500.
Now price out a jug of full synthetic oil - I like Super Tech - it is $20 for 5 quarts or $4 a quart less than $2 per oil change.
Now think this through - is it worth it to reclaim used oil?
To me no not worth it at all.
Plus I use up oil that I have on hand for my generators so it doesn't get really old.
The best new lawn mower I've seen in probably 20 years is the harbor freight 173cc.
It gets new oil.
The only ones I run reclaim oil in are oil burners.
I think your using the wrong term. As you are not reclaiming the oil. Its just plain old USED MOTOR OIL, period.
Heres the definition.
Reclaimed oil is used oil that has been cleaned, processed, and restored so it can be used again.
The exact meaning depends on the type of oil
  • Motor oil: Used engine oil is collected, filtered, and refined to remove contaminants. The resulting re-refined (reclaimed) oil can be used to make new lubricants or other petroleum products.
I cleaned it, if you were paying attention.
I tried calling it "used motor oil". People assumed that means full of environmental dirt, metal shavings, fuel, coolant, rain water, transmission fluid, grar oil, small bits of trash, grass clippings and everything else that might get thrown, blown or dripped into the oil collection pan.
