Originally Posted By: ryan604
If I get a MSDS for the Proline will it tell me if it is a dexcool clone?
And, if this antifreeze is indeed incompatible with the Pathfinder, how urgent is it to replace it? Should I do it immediately or can it wait until I can have a true "Flush" completed?
The MSDS will very quickly tell you PART of the story. If it says "2-EHA" or "2-Ethylhexanoate" on the MSDS, then it is at least a partial 'DexClone' because its using the same organic acid- and the one that has been implicated in damaging some gasket materials that aren't compatible. But it may have also contained silicates or phosphates, which DexCool does not.
You'll get varying stories about the 'urgency,' and I really don't know what to tell you. It all depends on the exact gasket materials used in the engine. Even GM blew that one and used DexCool in a generation of V8 and V6 engines that had lower intake manifold gaskets that would fail, with DexCool as a likely contributing factor. On the other hand, I'll bet dollars to donuts that if I were brave, I could go out and fill my 1966 440 V8 with DexCool and not have an issue, because it doesn't HAVE intake gaskets exposed to coolant at all, and head gaskets are not as likely to be affected (by the way- I won't do it, the 440's are happy with G-05). What I'm saying is that it all depends on the specific cooling system, and its hard to really KNOW if there's a potential problem or not.
Personally, as cheap and easy as a coolant flush is to do in the driveway, I'd swap it out some saturday morning and know that I'm golden.
OK, I went and looked at Pep Boys coolant selections. They seem to have eliminated the old "Proline" conventional for an all-makes/models tpe, and then they have "Proline Orange" which is a true DexCool. So I'm betting you did get a DexClone- an equivalent of Prestone all makes/ all models, a DexCool base with modified additives that don't really match any one manufacturer's specs exactly. I'd get it out if it were me.
