Earlier this week, I did the following work for an acquaintance. Listed below are the items that were done and their flat rate labor times (some of times have been reduced).
The vehicle was a E46 BMW 330ci.
Oil Change, engine and cabin filters, vehicle inspection = 1.0 hr
Spark Plugs = 1.0 hr
Lower Control Arms w/ bushing r&r (bushings from the old arms were re-used) = 4.0 hr
Inner Tie Rods (Both sides, also cut the old rods to re-use the boots) = 1.5 hr
Rear Differential Oil = 0.5 hr
Front Brake Pads and Rotors = 2.0 hr
Brake Fluid Flush = 1.0 hr
Diagnose Washer Fluid Leak = 0.5 hr
Total = 11.5 hr.
What would a reasonable labor charge be for all of the work performed?
The local dealer charges $150/hr, local shops are between $110-$130/hr.
Total = 11.5 hr.
