- Joined
- Oct 6, 2020
- Messages
- 2,533
Where IS it popular?Another thing not popular with BITOG. I never change Cabin Filters since I “cleaned” the filter in my 98 Continental. Dirty, but still did the job after over 100K miles.
It seems like the poster is unable to do that kind of physical workI would just do a gravity bleed yourself. Start at the furthest brake and crack the bleeder. Keep adding to the reservoir. Probably will take a quart to see clean fluid at the rear, maybe a little more. Then do all the other calipers. Probably will take another quart.
Done. Easy. Give your wheels a nice cleaning and rotate your tires since they're off.
I've had rear calipers giving me issues with random dragging, not overheating, just not acting properly and getting hot. 15-year-old car that never had a flush. Gravity bleed solved my issues with both calipers, two years since I did them and no more dragging.
buy a package of test strips and then you will know if it requires replacementThe Mercedes E300 has 55K miles and brake fluid has never been flushed. What does this normally cost? Have not inquired at dealer or independents yet.
Have not had any issues and fluid looks reasonably clear.
We just got this in the mail a couple days ago and I shared it with another member who pointed out "drain and fill" the brake fluid. I didn't pay that much attention when I got it.... First thought is they will just suck out fluid and refill the reservoir but who would call doing that a "drain" ? I understand that it's not unheard of for shops to do just that, use a suction to remove the dirty fluid that we can see in the reservoir and replace with new fluid. I hope that's not what they're doing !About $140 at the local Honda dealership for my wife's '16 CRV...about a month ago.
The more you get down and up the easier it becomesNot if you can't get down/up off the floor any more!
Yep me too. I have learned they take a SET to the axles they are on especiall on IRS. Luckily my current car wears all fours about equally.Another thing not popular with BIGOG. I only rotate tires if/when I see abnormal wear. Some cars, I’ve never rotated. If two tires wear out, I just buy two tires. If two are worn and other two still got 5k left on them, I’ll buy all four.
No, I watched them. However, I took my first CR-V to a local 'highly rated' shop for its first brake flush...at the time it was a lot cheaper than the dealer...found out why...they only changed the fluid in the reservoir. I think one of the popular Youtubers recommended doing just that...I think it was EricTheCarGuy???We just got this in the mail a couple days ago and I shared it with another member who pointed out "drain and fill" the brake fluid. I didn't pay that much attention when I got it.... First thought is they will just suck out fluid and refill the reservoir but who would call doing that a "drain" ? I understand that it's not unheard of for shops to do just that, use a suction to remove the dirty fluid that we can see in the reservoir and replace with new fluid. I hope that's not what they're doing !
If I recall the video you're referring to, he actually points out that some of his former co-workers/auto techs, did just that and considered it a "brake fluid exchange", to which he disagreed with.I think one of the popular Youtubers recommended doing just that...I think it was EricTheCarGuy???
Actually, he did both...see at about 16:50...but he gives his reason why (not sure I agree, but...)If I recall the video you're referring to, he actually points out that some of his former co-workers/auto techs, did just that and considered it a "brake fluid exchange", to which he disagreed with.
It makes perfect sense to suck out as much old fluid as you can via the reservoir and then use whatever method one prefers to get the remaining fluid out of the brake lines and calipers.Actually, he did both
You are probably right Ken, but at nearly 88 YO, my gitty up is about done for. I can still get my leg over the Cam Am three wheeler and ride 200 mi a day (now and then), but the next day I'm wiped out. Worth every bit of it tho. LOLThe more you get down and up the easier it becomesPITA job though 4 on the ground, or if you have to take the wheels off. Don't you have any nephews or kids to help you? Get 'em off their phones for a minute.
I just did the rear differential fluid on my wife's Subaru as the dealer wanted $131 to do a $37 job - as the car was on the lift having the oil changed. I revel in telling them NO way I'm paying that - that is highway robbery! You gonna make and old man get on the ground?! - Ken
That $200 price is about the standard price for a brake fluid flush at a Mercedes dealer. Typically Service A is about $300 and Service B is about $500 and the $200 difference is that with Service B, they flush the brakes. Sometimes you can find online coupons for additional discounts on Mercedes service and usually if you ask a Mercedes dealer, they will accept competitor coupons. Occasionally I still get $150 off $300 service coupons in the mail but I basically don't go because an indy is usually 1/3 to 1/4 the price of a Mercedes dealer so the savings are a mirage.Thanks folks for the rapid feedback. Just called MB dealer in Winston Salem and they said $200. I have an apt next Monday.
B service is usually $650-$800 depending on the dealer. Don't forget it also includes the cabin filter and some dealers are including wipers ($75-$150) in their service packages.That $200 price is about the standard price for a brake fluid flush at a Mercedes dealer. Typically Service A is about $300 and Service B is about $500 and the $200 difference is that with Service B, they flush the brakes. Sometimes you can find online coupons for additional discounts on Mercedes service and usually if you ask a Mercedes dealer, they will accept competitor coupons. Occasionally I still get $150 off $300 service coupons in the mail but I basically don't go because an indy is usually 1/3 to 1/4 the price of a Mercedes dealer so the savings are a mirage.
Your Honda dealer is an amazing deal ! At those prices they must be busy busy busyWe just got this in the mail a couple days ago and I shared it with another member who pointed out "drain and fill" the brake fluid. I didn't pay that much attention when I got it.... First thought is they will just suck out fluid and refill the reservoir but who would call doing that a "drain" ? I understand that it's not unheard of for shops to do just that, use a suction to remove the dirty fluid that we can see in the reservoir and replace with new fluid. I hope that's not what they're doing !
