If you look at the attached pictures you can see a before (first two pictures) and after (second two pictures) of the drivers side leaf spring assembly of my 22 Silverado. I have rear spring clunking (and still do). I suspect the “before” picture is as a result of me having taken it to the dealer and them “making sure” the mounting plates were tight. Look how unevenly tightened the rear leaf spring u bolt was. Also notice the bottom leaf was out of alignment with the rest of the assembly,. So I fixed this this evening per GM service information (tightening sequencing, etc). The way it looks after the fix are the second three pictures. The problem is now the rear u bolt actually touches the axle. On the passenger side spring set (unmolested by me) the rear u bolt is almost touching but doesn’t quite touch the axle. One, is this a problem worth digging back into? Two, is my alignment screwed up? The paint is undercoating I sprayed on the tiny amount of bare metal on the axle tube that was showing after I loosened and retightened the assembly (slightly different placement on retightening). Is this something I even need to worry about? You can see on the last photo what I mean about “touching the axle.”.The rear of the axle is to the top. Notice how that bolt is touching against the axle tube.
