I'm in the process of replacing the gas tank on an old Mustang and since I have ample access now to the rear end, I decided to put in new leaf springs and shocks.
That said, I want to make sure I'm doing this right:
1) Chock front wheels.
2) Remove rear tires (for access).
3) Jack up car, place jack stand under frame rail, just ahead of the front of the leaf spring; repeat for other side.
4) Place jack under rear differential and raise until pressure is just released from leaf springs.
5) Put jack stands on either side of pumpkin.
6) Remove u-bolts and plate from axle.
7) Place jack under leaf spring.
8) Remove rear shackle.
9) Remove front leaf spring bolt.
10) Lower jack and wheel away old leaf spring.
Re-install by reversing the order, then repeat process on other side.
Does this look right? Did I miss anything?
Also: The kit I ordered has regular rubber bushings. Do I need to lubricate these (looking to avoid squeaks)? If so, what type of grease?
Thanks.
M_C
Thanks.
M_C
