Rear Differential Oil
Florida
If someday, I would want to change the oil in my 2009 Dodge 1500, 5.7L pickup's differential, what would I use? Did synthetic come from the factory?
In ordinary use, when should it be changed?
My F150,which I traded in for the Dodge, had 111,000 miles on it with the original oil in the differential without any problems.
Should I use synthetic or ordinary oil? What weights?
Thanks,
Jack
Amsoil or Redline!! Im not sure what the 1500 takes but the ford too 75-140. I have been usinf Amsoil for years, but I did pickup some redline 75-140 for my F150 today
Originally Posted By: Onmo'Eegusee
Originally Posted By: panthermike
Schaeffer's
Do they even sell any gear oil in quarts? Last I looked, they want you to buy it by the pail.
Yes- My local NAPA actually carries Schaeffer's products and sells motor oil, transmission fluid, and gear oil in quart bottles.
Their website must be out of date then. I just went and looked through the product pages for all of their gear lubes. It shows a pail is the smallest size.
M1s diff oil will work great for you I have used it in the past with excellant results. My sons old Ranger has it in the diff with 336,000 miles with only one oil change during that time.
M1's gear oil specs are underwhelming IMHO, and ARE group III.
Originally Posted By: Mobil 1
Mobil 1 Synthetic Gear Lubricant LS 75W-140 combines wax-free synthesized hydrocarbon base oils...
As infrequently as diff fluid is changed, you might as well go for the good stuff. Not to mention M1 75W-140 sells for ridiculous money in my area, usually over $15/qt.
Hi,
Ben99GT - I have always believed that Castrol made some of the most advanced gear and transmission fluids available. My experience with these go back several decades
About 1998 I commenced side by side comparisons with GL5 fluids - Mobil 1 75W-90 and Castrol's Syntrax 75W-90. These vehicles ran in varying ambient temps and at utilisation rate at about 225-250kkms annually
At 1 million kms (or four year) OCIs and using used oil analysis and component attention data I could not detect any differences at all! I had no component failures and no seal issues
So there are many good synthetic fluids for these applications - Castrol and Mobil products are two of them!
Odds are that the manual calls for 75w140 synthetic.
Buy whatever 75w140 synthetic is easily available and not expensive.
Typically I go to NAPA and pay $12-$15 per quart.
It comes with limited slip additives from the factory.
Which I can no longer bring myself to do, not when I can get RL or Amsoil SG for $11-12 off of the 'net. And IMO, those two fluids are better than anything you can buy at the local parts house or at Wal-Mart.
