A have a couple of questions about my two trucks.
Truck No. 1: 2009 Chevrolet Silverado 1500 4x4. The owners manual doesn't state the truck has a limited slip differential nor does state the truck may be equipped with one. The truck requires a 75W-90 gear oil, that being said, will it harm the differential if I run the proper weight gear lube that contains the friction modifier required by LS differentials?
Truck No. 2: 2007 Dodge Ram 1500 4x4. The owners manual states the truck may be equipped with a limited slip differential. How do I determine if the differential is a conventional axle or LS differential?
This truck requires a 75w-140 weight gear oil. Why would this truck require this weight oil when the 2500 and 3500 series Dodge trucks require 75w-90 gear oil?
