Bought a permatex kit but did not work sanded flat used activator wouldn't work any advice on how to repair this
well normally it takes more than an hour.. and you gave us very little information..Any help
I prepped the tabs and mounting the so called glue wouldn't tack up I will post pics later
Link to actual Permatex kit would be helpful as well.
The guy at South main auto solders the tab back on. Have a look at his video. Maybe be tricky since you are in cold weather. Can you do this inside a closed garage?I used this per directions with hair dryer can I just put solder on the back of the tab and quickly press it to window ?
I wouldn check various videos on YouTube first. I usually check a few videos before doing the repair and watch the video 2-3 times, and then try to watch it about 30 mins before doing the repair myself. Some videos suck and are a waste of time, but I do it as part of my research.I did it yesterday in a heated garage I wasn't outside I will look at video and thanks.
