Oh yes they are!Is the Truck & Tow the cheese grater rotors? Mostly a gimmick if so.
And you lose precious braking surface too. There’s a reason why slotted and drilled rotors are part of a big brake kit.Oh yes they are!
I stand corrected... they are slotted and drilled.And you lose precious braking surface too. There’s a reason why slotted and drilled rotors are part of a big brake kit.
I've always used the factory Toyota pads on my 2007 Tundra...just turned 372,000 miles. Rotors are original at both ends. I think the front rotors were turned once at the dealer. They always check the run out and thickness and tell me they are fine and slap another set of pads on, and bleed them.On Toyota cars and trucks, I typically go back with the OE Toyota/Lexus or Advics.
Rotors: https://www.rockauto.com/en/moreinfo.php?pk=12880209&cc=1432805&pt=1896&jsn=1820
Pads: https://www.rockauto.com/en/moreinfo.php?pk=1874956&cc=1432805&pt=1684&jsn=1926
or: https://parts.belllexusnorthscottsd...ake-Pad-Set-RearRear/62992160/0446660090.html
Lol.I think @edyvw, has personal experience with this model. Further, any chance he can rip on Toyota he's right there. Regardless, I value his input on this site.![]()
