Rear brake caliper replacement parts options?
CA
Hello
I am working on my sisters 2000 VW Passat FWD that has been sitting for a few years.
I drove it for the last two days and there is a burning smell and a bit of smoke coming from the left rear wheel I suspect the caliper is seized.
What are the recommended brands people are using these day? new or remanufactured ?
Thanks
  • Wow
Reactions: D60
If it was me I'd be using whatever was the easiest/cheapest without the hassle of a core charge. May need pads/rotors as well depending on how long its been dragging. Looks like RA has a wholesale closeout reman for $65 no core charge..
  • Like
Reactions: D60
Hello
Thanks
You will get the best selection and price at Rock Auto.
Rockauto has a Pagid branded left rear caliper for $87.99, no core charge. It shows it coming with new slide pins, boots and copper seal gaskets for the brake hose. This is the left side, P/N 8E0 615 423, of course your own research will dictate the correct parts.
But,,, if it were me I'd take the old one apart and clean it and see if I could get it to free up.
Get all-NEW calipers, not reman/rebuilt, as most reman calipers aren't even "rebuilt" properly :sneaky:
Rock Auto has new Pagid calipers at a fair price :)
  • Like
Reactions: D60
Pagid should be a decent part. If it’s smoking I would plan on the caliper, pads, rotor, and maybe the wheel bearing.
