Real world MPG with 5w-40 vs 0w-20
JXW
Milford, MI (USA)
Driving a 2016 528i Xdrive with the N20 motor, 4 cyl single turbo. I have now logged over 90K miles on the car. In the early days I was using the BMW ll-17FE oils, 0w-20. Since I have changed to 5w-40, Revenol VST at the suggestion from a person here at BITOG. Yesterday I acheived best MPG on a tank and started to think about the fuel saving properties of the new oils. In my operation, I could not discern a difference whatsoever from the 0w-20 for MPG in both summer and winter driving from the current LL-01 oil which has much higher HT/HS.
  1. I use COSTCO gas (93)
  2. My drive routes are always the same (highway 95%)
  3. My driving style
  4. OCI interval between 8k and 10K
  5. Tire psi are set and checked
  6. Four season climate from -10F to 90F
Looking to see if anyone has experience that shows the variant to the oil weights does or does not improve actual MPG?
Yes, you have proven to the average driver that it makes no difference, but you didn’t defy the laws of physics. In controlled conditions, the measurements sanctioned by CAFE do show a small improvement for the 10’s of millions of vehicles out there. I run 5w40 in my Chevy 6.0 and also have not noticed any difference. Thanks for the post.
I am sure that the 0-40 must be providing a better protective coating for bearings and pistons and that may be what is causing your improvement in gas mileage. I just had new tires put on our 2012 Mazda 5 and our mileage went up at least 2mpg. Little changes make a difference. Her new tires are Falkens. Two tanks of gas now with same results. I keep records on each thing and every gas fill up since our purchase.
From what I've seen:
- When someone goes from 0w20 to 5w40, many posters talk about a hit to fuel economy.
- When going from 5w40 to 0w20, nearly everyone says that too many variables to notice fuel economy in real world.
Just an observation, make your own assumptions.
In my experience different brands of 5w40 gave different results. Back in 2014 when I had 2006 Pontiac Vibe AWD I tried every 5w40/0w40 on AutoZone/AAP shelf. All were same MPG as every 5w30 I used before. But with Valvoline MST 5W40 there was a huge drop in power (in lower RPM range) and MPG. MPG went from 28MPG average to 24MPG average. I dumped that oil within 1000 miles. Don't remember which 5w40 I refilled with, but MPG and power was back to normal instantly after the oil change.
You really can't make blanket statements. My experience in changing viscosities is how much 'reserve power' a vehicle has. In a V-8 vehicle (or turbo), the difference in fuel economy is so slight you would be hard pressed to notice. But in something like a Mirage or Saturn, that are under powered from day one, there is a chance you will notice an improvement in mpg with a lighter oil.
I know 5w30 vs 0w40 gave me no difference in mpg what so ever. I might dare to say 0w gave me slightly better mpg (0.2 mpg) difference.
I log every tank to a .xx gallon level.
My Mom and Dad each owned '95 Camrys. Dad always used 20w50 in everything. Mom forced Dad to go by the manual for her's - 10w30. Both made it to 300k miles. Their experiment "proves" thinner oils protect just as well as thicker one's do. No, just another anecdote. Unless done in a lab, there are just too many variables.
I would be running Pennzoil Platinum Euro 5W40 in N20 considering it has lower amount of Zinc which is better suited for troubled timing chain guides on that engine.
How does the Pennzoil Platinum Euro 5w-40 compare to the Ravenol VST 5w-40?
20w 50 and lasted 300k wow, A bit thick for that engine.
Both are exceptional oils. But PPE has Zinc below 800ppm and there is evidence that lower Zinc levels are better for timing chain guides. PPE is as current as it gets. GTL based oil so expect high HTHS, low Noack and good cold properties. Ravenol is also extremely stout oil but has more traditional additive pack with higher Zinc level.
I'll see if I can produce a data point.
I've got 8k km Mobil 1 5W30 in the Focus right now, so when it gets cold (around freezing) I'll do a cold start in the morning and track fuel used during idle for 5min using the scangauge, then when I change to 0W20 I'll wait for a day with the same temperature and idle the car for 5 min and compare the fuel used in 5 min. I'd think the 5W30 will cause a measurable increase in fuel use but not all that much. I suppose at the higher rpms of actually driving the difference in oil drag would be a bit more and it could be estimated how much.
  3. My driving style
I've seen a difference using thicker oils with low viscosity index like 15w40, but virtually no measurable difference between 5w20, 5w30, and 0/5w40.
It's worth noting however that 99% of my driving is at full operating temperature, I'm sure if I did lots of short trips it would be noticably different, considering 0w40 is more than double the viscosity below 100F of 5w20.
Actually not necessarily so. What we need to look at is how oils work. The #1 thing an oil does is keep the parts separated. If a 30 wt oil keeps the parts separated through out its operating mode there there won't be excessive wear then a 20W-50 would not reduce the engine wear because keeping the parts more separated will not decrease wear by being more seperated. There is much more to oil choice that this but this as a ground level explanation it is it,
Been thinking about trying Mobil 1 Extended Performance 0w30 in my Toyota 2gr-fe this oil change. Has had only Toyota and Mobil 1 0w20 since new (103k miles). Was interested to see if the engine is any quieter with it. Sounds like I might not notice any difference.
In my 2GR it was slightly quieter on 0W-30/5w30/0W-40/5W-40 than 0W20/5W20.
I ended up using Mobil 1 0W-40 and Quaker State Euro 5W-40 for the length of the ownership.
  • Like
Reactions: wlk
