Wait until I tell you that I break in new ratchetsOMG! Sealed for life ratchets as well as a new "thick vs thin" debate. What's next? ....show me the 'Toolfax'?
And change the factory lube after the first 1000 uses?Wait until I tell you that I break in new ratchets
By all means, clean and lube your ratchets. Quieter and smoother. Just don't over do it!I’ve never encountered much of a need to lube mine. Even the heavily used ones. Maybe I’m missing out on a smoother experience?
I just let the ratchets soak over a weekend once or twice a year.And change the factory lube after the first 1000 uses?
The very quiet clicking never bothered me, and my ratchets have never been not smooth. I generally run SO ratchets though.By all means, clean and lube your ratchets. Quieter and smoother. Just don't over do it!
Z-series 72T model ratchet handles are maintenance free. Do not grease up. High viscosity oil reduces upper pawl movement, which causes gear slippage.
I suggest you try cleaning and lubing your beautiful Snappy ratchets. The rebuild kits come with Superlube. Here's one of my older ones...The very quiet clicking never bothered me, and my ratchets have never been not smooth. I generally run SO ratchets though.
Just remember, you're not allowed to get any grease down in the threaded screw holes.I suggest you try cleaning and lubing your beautiful Snappy ratchets. The rebuild kits come with Superlube. Here's one of my older ones...
Will the new Maxlife/CVT work or should I stick to the ATF-only type?The sealed ratchets I do nothing to them the others I use ATF.
CVT only works with those new gearless ratchets.Will the new Maxlife/CVT work or should I stick to the ATF-only type?
Supco MO98 is what that Koken 72 teeth ratchet would get if I had one.Koken says this about their 72-tooth ratchets:
https://kokenusa.com/products/3-8-sq-dr-ratchet-handle-72-teeth-length-178mm-quick-release-z-series
If a ratchet skips you need a rebuild kit. The 3/8 long SO I posted was in need of new internals.I brought a pal's old 3/8" drive to the Snap-On truck who had 7 different guts but not for this relic. He ordered two sets and thanked my for the experience.
Also, his dad's 1/2" drive was known to jump and cause injury. I took that one and secretly mailed it off to SK in Chicago. I used his address so he got it back.
Cleaning either never crossed my mind.
