Random tick - Silverado 4.8
Florida
Changed my oil last weekend and noticed I have a random ticking/clicking noise but only after the engine is warmed up.
I doubt it has anything to do with the oil change, but rather I'm now noticing it because I was listening for any noise afterward (force of habit, I guess).
The tick is definitely coming from the bottom end, either from the engine or transmission. Could be an exhaust leak, I'm guessing, as well.
It's not really loud. I can hear it at idle only. No driveability issues to report of so far.
Just for the record:
Transmission is a GM reman unit with only 13k miles on it. Dealer installed it and haven't had any problems to report from it since. I have a magnefine filter on the return, since it was installed after the last A/T grenaded itself.
Engine is a 4.8 V8 with 61k miles. It is not neglected.
Oil out: Pennzoil Conventional 10w30 and Bosch filter
Oil in: Quaker State 5w30 with Napa Gold filter
I've read about the parking pawl or torque converter could be a problem. Also, drive shaft splines. Exhaust leak comes to mind. I read a few TSBs on engine ticks, but those were mostly for piston slap and diesels. Doesn't feel or sound like a u-joint.
I doubt it is from the engine, because it really purrs like a sewing machine and has since I bought it.
I know we have some excellent GM guys on here.
Any suggestions?
I forgot some really important information!
It only happens in gear, drive or reverse. It doesn't go away in reverse or drive. In Park, I can't hear anything unusual. Neutral seems for the noise to take longer to go away, but it does go away.
The clowns that put the transmission in didn't bother to put 2 of my engine block bolts back in either (driver's side). Noticed that last night.
Sorry for that!
Originally Posted By: bigmike
I've read about the parking pawl Also, drive shaft splines. Doesn't feel or sound like a u-joint. Any suggestions?
You said this only happens at idle...none of those things are rotating when the car isn't moving.
Or did I not read your post correctly?
Only at idle in gear. I can't hear it or feel it when driving.
Originally Posted By: 229
Flex-Plate crack.
Very well could be. I can look in the inspection hole and see if I see anything. Plan on crawling under it tomorrow.
Seems to only be when you put a load on the engine. If thats the case, I'd be looking at the flexplate bolts, torque converter bolts, or the flex plate itself as well.
