Need advice guys. I'll try to tell long story short.
Since I got Scan Gauge it alarms me about pending codes. I had engine light lit up ones or twice actually. First code that was popping up was p0171 Lean code (System to lean bank1).
Then I had couple random misfire codes P0300, P0301, P0303 (which mostly show up in pairs).
Pending Codes will pop up randomly every day, or ones a week. They go away by themselves most time, since I just snooze alarm if I'm driving. They pop up mostly at idle. And seem more to popup at start up in the cold mornings.
First I thought it is vacuum leak since I forgot to install metal gasket between intake manifold and throttle body,when I took valve covers off last summer and cleaned sludge out.
Anyway I installed brand new gasket at last oil change (2700 miles ago).
Also checked front spark plugs since I had couple sludge up pretty bad during chemical therapy for sludge removal. They were fine, no sludge or excessive deposits, just some red/pink tan from gas additives. ( same plugs I had, Iridium NGK)
Couple hours ago I came to work and was waiting for gate to open, Codes p0150, p0153 pop up on scangauge. I think I seen them once before. Codes mean: 02 Sensor Circuit Malfunction (Bank 2 Sensor 1) and Oxygen Sensor Circuit Slow Response (Bank2, Sensor1).
Ok, so here is my thought. O2 sensors were swapped out about a year ago, with OEM sensors (don't remember which ones, Bosch/NGK/Dayco).
I downloaded Toyota TBS about sensors and figure out that bank 2 if near radiator.
For some reason I was sure it was opposite (possible advice from here).
So I was checking wrong spark plugs, since cyl 1 and 3 is in the back and I haven't seen them since summer. They were not bad, but I cleaned them anyway at that time.
So now it makes my life easier since I know that bank2 is front o2 sensor ( I have socket for it), probably will be able to change it myself.
What do you think guys: Should I first swap out spark plugs in the back or my o2 sensor? Should I stop using my MMO/TWC3 mix since it might foil stuff?
Car in my sig.
That is how front plug (cyl 2, first on the left) looked like about a year ago
that is how it looked last oil change:
Car in my sig.
