P0430 code
wtd
southwest Mo.
Hi, I wanted to get some opinions from you guys on this code. This code popped up yesterday on my fiance's son's 97 GMC K1500 with the 5.7L. I hooked up my scanner and this is the code that was in it. This truck only has about 29,500 original miles on it. A couple of months ago, the distributor cap developed a crack and cylinders 2 & 8 were misfiring. The truck currently has a new distributor cap, rotor, plugs, wires, and a fuel filter.
Since the truck had been run quite a bit while misfiring trying to diagnose what the problem was and then ultimately driving it to a repair shop who discovered what the problem was, my opinion is that the excess fuel that was dumped into the exhaust from the misfiring has finally taken out the catalytic converter.
This code says this: P0430: Catalyst System Efficiency Below Threshold (Bank 2) The research I've done for this code suggests it could be several things that sets this code. One is a bad O2 sensor though there are no O2 sensor codes stored in the computer. Another is a leak in the exhaust system which I have looked and listened for that and don't see any signs of a leak, and lastly that the catalytic converter is bad.
While observing the live after cat O2 sensor readings on my scanner, the readings are switching back and forth pretty rapidly, just like the pre-cat O2 sensor readings which supposedly is another indication of a bad cat.
So for anyone here who has had this code come up on their vehicle, do you think a bad cat is causing this code? Are there any other tests that I can do before taking it somewhere for a cat replacement? Thanks for any ideas or info.
Wayne
If the after cat O2 readings match the front O2 readings or look similar then the cat has become poisoned. Running with a dead misfire for any length of time can damage the cat.
Yes. If you can pull up the rear O2 readings and compare them to the front, that is the best check.
If the rear O2 is switching at near the rate and amplitude of the front, the Cat is bad.
It should be switching at a much slower and a much lower amplitude.
I have yet to see a cat code (420/430) that is not a cat. The software is really good at figuring it out. Its really obvious if you look at the feedback from a good cat.
Thanks for the information. I was leaning toward a bad cat but just wanted some other opinions before we have it replaced.
I'd do a battery disconnect to reset it
then try taking it on a long highway trip 100miles or so.. and see if the code comes back.
most aftermarket cats are junk most oem prohibitively expensive.
I had a 98 Yukon that displayed that code after about 175,000 miles. I replaced the cats with Walker direct replacement cats. It worked out. My brother had that truck until about 225,000 miles.
Just make sure the aftermarket cats you get are C.A.R.B. compliant. They cost a little more, but are made MUCH better as they have to be certified for sale in California.
I agree most of the standard 49-state approved aftermarket cats are junk. There's a reason that they cost half or less of what an OEM/C.A.R.B. cat costs.
Originally Posted By: MarkM66
Put an O2 spacer on it and forget it.
+1 You will be replacing those aftermarket cats too often to be worth it. Those cats are designed for end of life vehicles. New cat at 30000, yikes.
This is the same truck that got overreved in a mud field right?
EDIT: Put the money into replacing the spider injectors. 97+ GMT400's only flaw.
Well the reason is that they just have to last about 25k miles instead of factory ones which typically have to last at least 80k, I think some Pzev cars have to last 15/150k.
Rockauto also sells them, don't forget the 5% off code, may help with the shipping.
Also some say that the used cats may be worth close to $100 in scrap value.
Yes, this is the same truck that was overreved in the field. I personally have had good luck with aftermarket cats. I've put 150,000 miles on the aftermarket cat on my 92 cavalier and it still works fine. I've had an aftermarket cat on my 98 K3500 with the 7.4L for the past five years and it's still fine.
This is not my truck so I don't have the ultimate decision on how it's fixed. My fiance' wants it fixed and does not want the CEL to be on. She already has nixed the spider injector replacement from when we had the misfire situation. The truck runs fine other than the CEL is on.
Thanks everyone for the input. She has not decided which route to go right now other than she wants the cat replaced.
Aftermarket cats are not a problem as long as you're not burning oil
^ This is true.
Yes they are. The washcoat when new is barely good enough to squeak by and pass emissions.
I had a bad NOx catalyst in my older BMW (no EGR), and so I swapped the cat, the results were literally a few PPM lower, just enough to squeak by.
OE cat had me from around 1100ppm with old and replacement aftermarket, to 11ppm!
I would warm it up, take it out on the highway and drive it near max rpm for 10 miles or so (just drive the speed limit in a lower gear). This does a great job of heating up the cat, and might bring it back to life. After doing that, clear the code and see if it comes back.
Cats don't die, they are killed. Mileage is not really related.
If the check engine light was flashing during the misfire, that means the cats are being damaged by driving.
The CEL was flashing during the time it was misfiring and the misfire was verified by viewing the live data on my scanner. This is why I think that the misfiring on two cylinders on bank 2 has caused some damage to the cat on that bank. This truck has two cats, one for each bank.
I will try clearing the code and see if or how long it takes for the CEL to come back on.
Agreed, IME here the cats last the life of the vehicle as long as they are not abused.
