2008 Jeep Wrangler X, 2 door. 3.8L engine, 6 speed manual transmission, 100K miles. Started throwing a P0430 code -
My question is: Does this code affect fueling, or does it just cause the ECM to set a code to alert that the cat appears to be bad. Does P0430 change engine fueling or timing parameters?
Thanks
P0430 Code: Catalyst System Efficiency Below Threshold (Bank 2).
Thanks
