Ram 3.6L Pentastar oil cooler replacement
Erie, PA
So I have watched this repair of the caravan's and the jeeps, and this whole repair looks quite easy. Bigest issue being the time and labor to clean and degrease all the oil mess.
However with the ram 1500, even with the front tires removed and the rotors on the ground, there is not really a very comfortable way to do this job. The engine sits close to the firewall and reaching anything is tough. Has anyone done this job that can offer any tips?
And would anyone trust this for the low cost?
https://a.co/d/i7CWBBn
Haven't done the cooler on a RAM, but have done a few minivans and a Wrangler. You're correct stating the job is more time consuming than difficult. But, seriously..."Boeeda?" Would you really perform a few hours' labor and a bunch of cleaning to install a Boeeda? Don't cheap out. If you don't want to pony up for a Mopar replacement, at least buy the part from a company a tad more reputable than one from a back alley in Beijing.
And before buying a replacement, diagnose leakage (if that's your issue). The coolers aren't all broken...some merely suffer from flattened/leaky seals.
I'd order a Dorman from RA and a topside creeper from Amazon. Not joking.
I also don't trust the Dorman seals so I order them separately. I can't prove the Dorman seals are suspect.
Please don’t order that Chinese made garbage from Amazon.
However, if you do, please post pics and video of your truck broken down on the side of the road spewing oil, along with an “I can’t believe this would happen” sob story.
Best advice in the thread is to order the Dorman.
@Fordiesel69 I'm 10k into my new Dorman aluminum unit on our T&C. I'd do it again over the plastic OEM one. I did use the seals included with it from RA.
@wwillson did a nice write up on doing his Durango. Is that at all similar for you?
Just my $0.02
A durango would be similar to mine but much less reach. I am not concerd about the technical aspects of the wrenching and how to do it. I wanna know how the heck to reach it for 3-4 hours. Just taking the air snorkel off was hard.....
Get a step stool, lay a foam mat across the grill so it’s more comfortable laying your body on it to ease the strain on your back. That would be my suggestion.
  • Like
Reactions: JTK
I installed the Dorman with new Mopar seals as well.
The only Dorman seals I used are the "Figure 8" seals between the cooler and the housing. Mopar does not sell those for some reason. Some people have had those fail on them, and so, after reading a few forums I decided to lightly coat those in Permatex Ultra Grey for added strength. Hopefully it lasts.
DORMAN DESIGN:
pxl_20230318_204333440-jpg.4576028
Mopar has actually recently updated the design and part on their plastic housing, where they added an extra plastic "rib" between the "figure 8" seals, and actually separated them into different materials.
img_4053-jpeg.4610307
1000003099-jpg.4623326
20240305_035357-jpg.4623325
DORMAN DESIGN:
I glommed on to wwilson's thread as I didn't like one of the Mahle seals, so did use the Dorman there:
Post in thread 'New Dorman oil filter housing/oil cooler installed on 2014 Durango' https://bobistheoilguy.com/forums/t...installed-on-2014-durango.375802/post-6949510
I’d use the Dorman cooler with an OEM Mopar sensor and seals if it was me.
If the newest revision of the OEM Mopar design proves to be better, I’d go towards that so a quick lube or dealer lube can install the “right” filter. I assume Mahle Behr or Hengst made the OEM part.
I wonder just what was the "thought" process of putting an oil passage right next to a coolant passage separated only those gaskets. As we all know, antifreeze contamination in the motor oil is death to bearings. I really wanted another Wrangler or a Gladiator, but I absolutely HATE that oil filter housing design!
Not sure of OP's model year? It uses the "later" filters so on some it still uses whatever the book would say. I think the issue was on the earlier JKs primarily
