about a year ago I had a new radiator put in. 99 maxima
the top mount on both sides seems loose- that is the pin sticking up from the radiator itself is small in the hole from the "mount" that lays over the top of the radiator. you can move the radiator top maybe 3/16 of an inch. is this good or bad?
mechanic uses napa and their stuff is mostly chinese so maybe the rubber part is wrong size or the mechanic left out a piece, should I put a rubber piece like from a rubber hose around it? of leave it as it is?
I can see reasons for having it loose and for having it tight
HAve a pix but cant post it
