quote:
Originally posted by MN Driver:
The more pressure that is under the cap the higher the boiling point becomes. How much pressure is the radiator cap rated for? Coolaning systems would probably blow at 20 psi. I would make sure that all of your hoses are in good condition should the pressure reach the rating of the cap. I have a feeling that there would be no problem with the stock cap and that you probably wouldn't experience engine temperatures approaching the boiling point. I'd say go for it as long as you've got good hoses and it isn't above a 20 psi cap. My 2 cents.
...What are you towing?
