I'm in a bit of a predicament right now in getting Honda to honer my extended powertrain warranty on my 2008 Honda Civic EX. I have never had a problem with my car in the past burning oil, but between my last oil change and this failure, apparently my engine was able to burn off [censored] near ALL of the oil. I even topped it off with about a quart of oil about ~2 weeks prior to the engine failure. My engine only has ~70,000mi on it btw.
How and why this happened is what leaves me stumped so I figured this forum might be a good place to ask. The service manager that tore my engine apart said that my engine is totally clean and in his own words said, " There is no evidence of any lack of maintenance from looking inside the engine and oil pan." He can not explain to me where the oil went to though when I asked him for an explanation. There were no leaks found or anything like that. So, when the HondaCare warranty adjuster came and took photos and the service manager said he can't explain where the oil went, they automatically jumped to the conclusion that I simply didn't check my oil and because I don't have complete service records because I did my own oil changes (yeah, learned my lesson on keeping all my receipts).
I know there are TSB's on my engine for the block cracking, porous block, and head gasket problems. That alone just makes me think something is up with this because there is no way my engine consumed all that oil between oil changes if it was operating properly. Additionally, I saw no spike in engine temperature and no low pressure light until I had to brake hard one night and the oil lamp flashed. Which, is what made me check it and top my engine off in the first place.
Any help or explanation is greatly appreciated! Right now I'm looking at 4-5k for this repair alone plus my rental fees. Not that it matters but I've only run Pennzoil Platinum and Purolator oil filters on this car since day one and a brief run with Amsoil 5w-20XL. The service manager is trying his best to help me out and the district manager from Honda is involved now, but I have yet to speak with him or receive word on any conclusion.
