I have a weeping fuel pump block off plate on a 1997 5.7 Yukon. This is the small plate on the front passenger's side of the 350s where the fuel pump was installed in previous generations. I've had good luck with paper gaskets in the past and with the issues curing RTV in the winter, I decided to order a Victor Reinz paper gasket for all of $.18 from Rock Auto. (This may be the cheapest car part I've ever purchased.) When the package came, it had 7 gaskets inside.
Here's my question: Does it make any sense to double or triple up on the gaskets, or should I just use one? They're very thin. Not sure if if multiple gaskets would help or mess things up.
