Crankcase breather is on the other side of that baffle on passenger side valve cover. I think I used rubberized felt Victor Reinz VC gaskets last time. I used Felpro this time and hope to not smell burning oil again.
This 214.5K engine ( rebuilt @172K) has been using circulating Mobil 1, 10w-40HM, Mobil 1 Turbo Diesel Truck 5w-40, Mobil 1 Advanced Fuel Economy 0w30 and Mobil 1 0w-40 SN since about 185K miles. Previous to that was castrol or valvoline conventional 10w-40.
Since 172K miles, oil Filters have been Wix 1515, Puro classic 30001, Mobil 1-301. Motorcraft FL-1A. The several Puro classics and Motorcraft did not tear.
Oil changes are ~ yearly, or in this case about 18 Months. Mileage under 2K this OCI, Climate is mild, all trips have been very short trip driving with a very rare longer freeway driving. There was a half can of lubromoly Mos2 in this latest batch.
A few years back Blackstone found low levels of Potassium and sodium in a sample of 0w-40. I knew I had a slight timing cover coolant leak, was hoping it was not getting into oil. So much for hope.
Never fixed it properly, Bars leak gingerroot tabs stopped coolant from reaching asphalt. Yesterday, drained coolant, pulled WP bolts that penetrate water jacket one at a time, cleaned old rtv and corrosion from them.
I used permatex aircraft form a gasket on threads, and re installed them, waited 24 hours then refilled coolant. No visible coolant leaks. Yet.
I have not yet pulled driver's side valve cover. Tomorrow.
I will change oil after replacement. I will be using use a Fram Ultra XG-8A and Mobil 1 0w-40 again, removing a low mileage 15 month old Mobil 1-301. Expect pics of its internals.
