bigblockbuick
Thread starter
- Joined
- Jun 28, 2024
- Messages
- 13
Yes unfortunately it was leaking before. I have used a shop rag to kinda clean up the area. I am very fearful of using rtv. I Have seen a handful of engines with rtv in the bearings because "mechanics" used it on a oil pump.Was this assembly leaking before you discovered the damage? It doesn’t look like it. I would suggest telling the customer, saying the only real solution is a new block (?) and manage moving forward by careful installation of new oil filter and gasket. JB Weld or RTV are liable to make the situation worse if they break off, or add more irregularity to the sealing surface. Whoever dis this was a right piece of work.
