Originally Posted by Kira
Much as above. Everyone I know goes higher than placard.
NASTINESS WARNING: People simply using the placard as gospel without considering specifics and unknowns is like people who obey "lifetime transmission fluid" claims by car manufacturers.
Involvement is necessary.
I always gauge wear and adjust up or down to achieve even wear across the tire.
But In our broken roads around here, the impact harshness goes WAY up if I'm more than 3psi over placard. which would be over 37psi in most instances. I've knocked Strut top Bearing Races out of a few cars running 35-37psi ( Mazda 626, Mitsubish 3000GT)
I also do some hard 50- 60 mph slalom testing after adjustment on the local highway (when low traffic) to look for propensity to spin. I would say that many PASSENGER cars would get very tail happy when you approach 40 psi in the rear tires. Im usually down 1 or two PSI over the fronts in a FWD machine.
And now, there is more tuning to terminal understeer now than I have ever seen before. '
And we have those Ninny Nannies - ASC, ASR now too.
Most people where I worked never looked at their tire pressure or oil level.
And that was a cutting edge data and comm tech contractor.
