- Joined
- Mar 19, 2022
- Messages
- 881
A Toploader as coined by Ford was designed in 1963 and used from the 63.5 MY on in all big power Fords. Previously Ford used the Borg Warner T10 which has a side cover. Those had unsyncronized 1st gears. In Toploadeds all forward gears have syncros, 3 and 4 speed.
Some of the economy cars still used the BW T10 or a variation of it. To save pennies the 1st was not syncronized. GM, Ford, and Chrysler all did this.
A Toploader was a name coined by Ford for their new transmission made for the muscle car era. GM made the Muncie M21 and M22 which is a side loaded Aluminum case, which is known for its less precise shifts due to the shift linkage.
The toploader gets its strength from the iron case, and the design of the shift rails which the shift forks slide on, making for better shift quality. And continuous iron sides on the case where the stresses of the gearset are strongest. The Muncie with aluminum case and open side is weaker.
By today's standards, they are all slow and heavy.
Lighter gear sets make for faster shifts at HIGH RPM, back then everything was heavy with big forged bronze syncro rings.
This is a late 60s 3 speed next to a late 70s 3+OD. The unpainted case is the 3 speed capable of holding 400HP. The width of the gears being the limiting factor. You can see on the main shafts the difference. The longer one being the 400HP one. A true 4 speed toploader in the 31 spline output and 1-3/8 input is the 500+ HP version.
