Hey everyone when I bought this little Saturn a couple weeks ago the shifter assembly was bound up and made it very hard to shift and the master cylinder for the clutch rod had broken loose from the master so both of these parts needed to be replaced so I did that and I was hoping that that was the reason it was grinding in fourth. (Probably a long shot). So I did all of this I changed the fluid and I just used O'Reilly's house brand Dex 3 ATF and the car still grinds going into fourth when shifting normal. If I press the clutch pedal for about 3 seconds and then shift it'll go right in. Doesn't pop out of gear once it's in either. I'm pretty sure fourth gear synchro is just weak. Question is is there a certain fluid that I could put in the transmission to maybe help the synchronizer work better. I know some guys have ran synchromesh in these I don't know if that would be of any benefit or not. I realize that eventually the transmission will have to be replaced but for now if I could get by for a while with a Band-Aid I'd like to do that. It's just a cheap runabout anyway. What's your thoughts? Car shifts flawlessly in to every other gear.
