May I play the devil's advocate here?? IF and I say again IF the iron readings are from "chemical leaching" with the 5W30 product and IF M1's formula is so unique as to cause such then why do the 5W20,10W30,and other weights not exhibit this "leaching" process? Only the 5W30 has the unique formulation? Vey doubtful. Only the 5W30 produces iron particles that can be picked up in a used oil analysis? Even more doubtful. Then used oil analysis are useless to determine wear,unless of course a M1 product shows well then all the faithful chime in about how great it is. If Havoline,Valvoline,SOPUS,Schaeffer,Amsoil,Royal Purple and any others I forgot to mention went out-of-business I use the 5W30 M1 product without reservation. Well,no I would not... I'd use the 5W20 instead. Well, no, I'd just use Warren Products.
