I've read some comments on this forum concerning oil consumption when using M1, and I actually have first hand experience with this. My '96 Cavalier daily driver with the 2.2L engine was on a diet of M1 from 15,000 miles until 142,000 miles. During that time the oil consumption varied, but probably averaged around 1 qt every 1000 miles. This consumption was essentially the same with 5W30 & 10W30.
Tired of the makeup oil expense, I switched to TropArtic last summer. At first the consumption dropped only slightly, but then it gradually improved. It got much better after I added 1/4 bottle of VSOT...to the point where the car now uses only 3/4 qt every 3000 miles.
My question has to do with why the car used M1. Does this have anything to do with the PAO chemistry? The TropArtic is a synthetic blend, but the synthetic component is a GpIII oil. I'm guessing that the VSOT helped clean up some piston rings, but I'm surprised that they needed cleaning considering the car had run M1 most of its life. I'm thinking about running synthetic in it again, but this time using a 100% GpIII synthetic like SynPower since I am leary of using a PAO oil in the car again.
By the way, my wife's 2001 Grand Caravan and my '89 GTA (171,000 miles) don't use any oil at all.
