QuantumBlue(TM) Catalyst [and Lubricants]
found this , dynamicdevelopment.com ,not much info, and expensive.
no direct links to non site supporters,mark
[ November 08, 2003, 11:17 PM: Message edited by: rugerman1 ]
" It will rebuild their worn parts without disassembling the engine and replacing parts.
In newer cars and trucks - QuantumBlue Lubricants will preserve engine and transmission parts many times beyond their normal expected life span... Using the combination of Mineral Synthesis(TM) base oils with Thermal and viscosity shear stability and chemical grafting technology, components will run and sound much better, quieter, and smoother than even new! "
Wow! Let's see, how many more technical sounding words I can squeeze in there baby!
Just saw some mention of this stuff on a truck board. Hasn't been (dis)cussed on BITOG yet.
EDIT: I didn't mean to post those URL's. Here's the text of the pages:
quote:
QuantumBlue(TM) originally was developed for Missle manufacturers, and tough aerospace and NASA applications. The remarkable benefits it offers are as useful for automotive needs. Wear on working metal parts will be reduced 90% with simultaneous friction reduction of over 40%. This means the parts can last ten times longer when using QuantumBlue lubricants. For example, when a vehicle has been driven 100,000 miles on the engine, you will only find 10,000 miles of wear on the parts. Older engines can benefit from using QuantumBlue Lubricants also. It will rebuild their worn parts without disassembling the engine and replacing parts.
In newer cars and trucks - QuantumBlue Lubricants will preserve engine and transmission parts many times beyond their normal expected life span. Using the combination of Mineral Synthesis(TM) base oils with Thermal and viscosity shear stability and chemical grafting technology, components will run and sound much better, quieter, and smoother than even new! Simply specify the weight of lubricant you wish to use, and BND Automotive LLC with blend it for your application. It is best to change your oil and filter to the QuantumBlue Lubricant after 500 miles of the normal break-in interval on new vehicles. Always follow the manufacturer's recommended oil and filter change interval.
In older cars and trucks - Change the present oil and filter and add the QuantumBlue Lubricant oils like any regular oil. The Chemical grafting goes to work immediately and begins to "reverse the wearing out process." while the shear and viscosity stability catalyst seals the rings in all 4 strokes. Cylinders with low compression will begin to be rebuilt. The improving period will continue for several thousand miles at which time performance will be significantly improved. This is accomplished by reducing the large tolerances between worn parts, producing a hydrodynamic seal on the rings, and the Chemical grafting adjusts the surface metallurgy of mating parts. Subsequent wear will be reduced for an extended life time and reduced maintenance costs will be the results.
For manual and automatic transmissions - drain grease or fluids if possible. Refill with QuantumBlue transmission fluid or gearlube (refer to manufacturer's specifications for weight) and our specified technology will go to work reducing wear and friction immediately.
In differentials, refer to manufacturer's weight of lube, and introduce it as normal. BND will assist you by blending the formulas to work in all types of differentials - For new or older units, QuantumBlue Gearlube will preserve and quiet the differential.
In wheel bearings - QuantumBlue Catalyst is very useful in wheel bearings. A few drops can be splashed into each bearing or some mixed into bearing grease. When mixing in, use approximate 5% by volume and stir into the grease. Apply the mixture as you would normal grease. Rolling resistance will be reduced as will heat and wear.
QuantumBlue reduces metal part's wear by 90%,
compared to 5% with previous technologies
quote:
How much does QuantumBlue(TM) Catalyst improve the best selling Motor Oils and Additives ?
The following are examples of WEAR tests run to part's failure, comparing a variety of best selling motor oils and additives, "with" and "without" QuantumBlue Catalyst in them.
Pennzoil 10W40 motor oil
When QuantumBlue Catalyst was added to this popular motor oil, the time to reach engine part's failure was extended by 38 times compared to tests run without QuantumBlue Catalyst in this oil.
Quaker State 10W30 motor oil
When QuantumBlue Catalyst was added to this best selling motor oil, the time to reach engine part's failure by was extended 10 times compared to tests run without QuantumBlue Catalyst in this oil.
Tufoil (Teflon base)
When QuantumBlue Catalyst was added to this oil additive containing Teflon (a similar formula to Teflon based Slick 50, Nu Power, CD-2, etc.), the time to reach engine part's failure was extended by 16 times compared to tests run without QuantumBlue Catalyst in this product.
ARCO Graphite
When QuantumBlue Catalyst was added to this oil containing graphite, the time to reach engine part's failure was extended by 44 times compared to tests run without QuantumBlue Catalyst in this oil.
Ollomo (additive containing molybdenum disulfide... when mixed with moisture and carbon produces concentrated acid)
This oil caused part's failures so quickly the product was considered unacceptable. The moly was filtered out, then the remaining base oil was tested "with" and "without" QuantumBlue Catalyst. When QuantumBlue Catalyst was added, the time to reach engine part's failure was extended by 25 times when compared to tests run without QuantumBlue Catalyst in the base oil product.
Mobil 1 (synthetic oil)
When QuantumBlue Catalyst was added to this popular synthetic oil, the time to reach engine part's failure was extended by 4 times when compared to tests run without QuantumBlue Catalyst in this synthetic oil.
They also market lubricants with this "technology":
quote:
Why Switch to QuantumBlue Lubricants?
QuantumBlue(TM) Lubricant Oils are the ultimate leap beyond any lubricant oils available at any price. They are formulated using a highly refined Mineral Synthesis(TM) premium oil base stock that exceeds ALL the latest API specifications. The oil is then blended with special proprietary molecular shear, viscosity, and anti-wear technology designed for severe military and space applications. Wear on all surfaces is effectively reduced by 90% with simultaneous reduction of friction by over 40% compared with regular Petroleum, Synthetic or blends. In engines, piston ring seal is maximized in the oil from below the piston for virtually no blow-by. Special friction modifiers in the transmission formula allows friction where it is applicable while greatly reducing wear and friction which generate heat.
" QuantumBlue Catalysts;" were developed for the Rocket Industry and Military applications requiring molecular shear and viscosity stability parameters that have to perform far beyond any other known lubricants. This technology has resulted in a "breakthrough" in wear reduction of 90% and Friction reduction of over 40% beyond traditional lubricating oils Mineral or Synthetic. With greatly reduced thermal and viscosity breakdown, working surfaces of the mechanical parts can last 10 times longer than their normal life span. One of the characteristics that QuantumBlue Lubricants exibit is thermal and shear viscosity stability well beyond even combustion temperatures. This means that in engines piston seal is assured in all 4 strokes instead of just 3! In 2 stroke applications, the catalyst is not burned off on either stroke. In transmissions, differentials, and hydraulic systems like power steering, the oils do not breakdown under heat which extend the life of those lubricants twice times. Another characteristic of QuantumBlue Lubricants is a process called Chemical Grafting.
Chemical Grafting creates new material on surfaces of working mechanical parts. The material is grafted on through chemistry to provide far greater anti-wear properties than the original surface of sliding, turning and meshing parts.
QuantumBlue's chemistry reacts to the surface of the metal parts UNDER WEAR PRESSURE and modifies the metal surface without annealing it. The resulting proprietary process creates anti-wear, anti-friction, and molecular shear and viscosity stability properties on and between the mating surfaces of the metal parts.
In addition, QuantumBlue's chemical grafting capabilities are able to rebuild surfaces of worn metal parts without disassembly. For example, in auto engines, the rebuilding process results in improved compression for increased horsepower, torque, fuel economy, and reduced motor oil contamination and usage.
The chemicals combined in QuantumBlue Lubricants react at the surfaces of rubbing parts where pressure is exerted on those parts as they are forced against each other. The elevated temperature and pressure combine to produce the new benefits.
When QuantumBlue Lubricants are used in new mechanical equipment, its wear reducing capabilities are able to perform from the very beginning of the machine's life. The result:
Maximum extended life span and continuous maximum performance throughout that extended life span.
If QuantumBlue Lubricants are introduced after wear has occurred, it results in increased mechanical performance by reconstructing worn surfaces through bulking them up with a renewing technology. The modification of the surfaces reduces spacing between the mating parts (tighter tolerance) and greater retention of oil. In addition, the modified surface metallurgy will reduce subsequent wear by 90% leading to parts performing up to 10 times longer than without QuantumBlue Lubricants.
The anti-wear properties that become grafted on the surface's of the parts, serve as a remarkable, continually renewing, mechanical barrier against WEAR. The anti-wear properties are continually replaced, on an as needed basis and over build-up cannot occur. This advantageous grafting process has never been available before QuantumBlue's Lubrication Oils formula.
Key to this new technology is its continual creation of more useful surface metallurgical properties on working metal parts with stabilized viscosity and shear characteristics. The benefit of continually creating improved surface properties cannot be manufactured into metal parts. Use of QuantumBlue lubricating oils and in greases offers the only way to continually upgrade performance of working mechanical parts and greatly increase their life span.
QuantumBlue Lubricants are manufactured in any and all viscosities. Since its chemical properties are pure liquid technologies, it contains no harmful particulate materials to clog oil filters or oil passages. Such particles sinter and become abrasive when exposed to combustion gas temperatures. QuantumBlue Lubricants eliminate that possibility.
QuantumBlue Lubricants are manufactured by BND Automtive with our own Mineral Synthesis(TM) base stock lubricating oils. Mineral Synthesis(TM)is the next generation of base oils. It is beyond traditional mineral, synthetic, or mineral/synthetic blends. We hydro-treat the oil, take all the reactive hydrocarbons out of the oil and produce synthetic characteristics out of mineral base. Benefits of mineral and synthetic without the drawbacks of both in their traditional forms. This makes them perfect for both two and four stroke applications, transmission fluids for hydraulic and electronically shifted applications, multi weight gear lubes, air tool oils, any hydraulic application for reduction of pump temperatures etc. BND Automotive also produces QuantumBlue manufactured special oil combinations for various applications upon request.
The most important reality about our formulas are that they contain no outdated technology that uses: Teflon, moly, graphite, liquid metals, extreme pressure additives or paraffin which are all ineffective by comparison and solid particulate in composition. Nor does QuantumBlue contain any petroleum distillates which are added to other products to act as inexpensive, container filling materials.
QuantumBlue reverses the wearing out process and greatly prolongs the life span of all mechanical parts!
Anybody ever heard of this stuff?
Do a Google search for the web site.
[ November 05, 2003, 12:10 PM: Message edited by: doyall ]
"Our marketing department has spent millions on developing new and exciting ways to dupe you the customer into thinking the crap we sell in 12oz bottle will dramatically improve the performance of your car and make it last much longer."
Advertising it everything.
