Quaker State Ultimate Durability 10w30 In Honda ?
PNW
I recently came upon a like - new Honda Lawn Mower (190cc) HRX217 . Not knowing when the oil was last changed , I had a quart bottle of Quaker State Ultimate Durability 10W30 SN in my stash ... Hoping the oil is stout enough in the Honda with good cleaning for approx. a 25 OCI . Anyone using 10W30 Quaker State Ultimate Durability in the small engine power equipment ?
OPE engines aren't stressed. Keep an eye on the oil level just to be sure.
I've used conventional 10w30 in my lawnmowers Honda 160 without issue so the dino should work even better.
Tell project farm - He will do a video!
Can I run a Premium Synthetic Automotive motor oil in my Honda Lawn Mower? Lets find out ....
My 20+ year old Murray 3.5HP Briggs has had everything from 0W20 to 20W50 Harley oil in it. The bottom of the sump is spotless clean aluminum. I don't think these lil' engines care one bit.
I disagree with that because they typically run under a constant load and filthy conditions.
You actually change the oil ... THAT is what is most important to these engines. Most lawnmowers go a decade with no oil change ... DIE ... and get replaced.
My lawn mower was purchased new in Oct 2004; wrote that in black sharpie on it. I've never changed the oil; it's still honey colored. I DO check the level, it actually has a dipstick. Full disclosure, it's stored in a heated garage, and I actually HAVE a lawn, so it's NOT used in dusty conditions. Starts every spring on first or second pull...BTW, it has AMSOIL Signature Series 5w30 in it.
I'm impressed you should do a used oil analysis on it, the commercial grade oil is pretty impressive you should look into it, heavy ZDDP dosing
You will be absolutely fine with the QS in there. I have a Troy Bilt push mower with the Honda gcv160 and I have Pennzoil Platinum 5w30 leftover from the truck in it but I also use Delo xle 10w30 as well. The QS really is an awesome sleeper oil and gets overlooked by so many.
I tried Quaker State Ultimate Durability 10w30 in my car for about 3000 miles. Never again will I ever use that oil. I thought my engine was wearing out.
Do explain....
If you've never changed the oil, how did the AMSOIL Signature Series get in there ... ?
Originally Posted by BigShug681
Do explain....
Mechanical noise. It's the sound an engine makes when it's not being lubricated properly. There's been lots of complaints about Mobil 1 5w30 being the culprit of mechanical noise. I've never experienced the Mobil 1 noise first hand, but if it's anything like Quaker State Ultimate Durability noise, I wouldn't recommend it.
no readings, no theory, just noise about noise …
interesting this same company provides base stock for a couple dozen blenders too …
The plot thickens...
Do explain....
Very interesting
Just a description of my experience with the oil. An eyewitness account. I'm not saying people shouldn't buy it. I'm just saying I will never buy it again and will not recommend it.
It completely meets Honda's oil recommendation specs. So it would be no doubt up to the task. Better than 10w30 conventional that Honda recommends. II do have 5w30 Quaker State Ultimate Durability in my B&S engined Snow Blower. I also once used that oil that ran an interval in my Kawi FR730V for 40 hours. Didn't need to add a drop.
