I believe that the Quaker State Ultimate Durability is the old(er) labeled oil. Now just called QS Full Syn.
If I had a choice, I'd choose that one.Is Quaker State Ultimate Durability same as QS full synthetic?
So it is better now?Quaker State Full Synthetic is API SP whereas Quaker State Ultimate Durability was API SN+.
"Better" I honestly cannot answer, I'm guessing a more current add pack that meats the newest API standards. Me personally, I would go for the newest formulation. I'd guess it should be better since lubrication is an ever-evolving technologySo it is better now?
Basically. Also d1g3 approved which is an improvement over d1g2. But gm only gives it to 0w-20 and 5w30 grades not 5w-20 or 10w30 which I think is silly.So it is better now?
I am running the 10W30 in a 5W20 application and its is fantastic. Can't say enough good about it.Basically. Also d1g3 approved which is an improvement over d1g2. But gm only gives it to 0w-20 and 5w30 grades not 5w-20 or 10w30 which I think is silly.
True but generally a newer approval is gonna mean a better overall formulation but not always. But I'd still happily run the non dexos grades in my 2021 anyway and expect the engineering or manufacturing to be the reason for a failure and not the oil.I am running the 10W30 in a 5W20 application and its is fantastic. Can't say enough good about it.
I will avoid high VM ( vii) treatment if I can, they are vanish sludge and gum makers, thus the 10W-Xx.
GM doesn't spec a 10W30 or 5W20 so no Dexos in those grades. Those grades are more of a FORD thing.
I don't chase DEXOS approvals, it has never done anything for me that I could tell. Whatever that means![]()
