1) OP made no mention of having an OLM.@atikovi
You gotta play fair man, what you referenced is for vehicles without the OLM. My gut says most if not all of these had the OLM as standard by 2001.
2) OLM is a marketing tool to help sell cars by implying they are low maintenance. Changing oil according to is will get the engine through the warranty period, but 7000-8000 mile OCI ain't that great for longevity as OP is finding out.
Recommended oil change interval for a 2001 Buick is 3,000 miles. Seems like trying to save a few bucks by extending oil change intervals is going to cost you in terms of increased engine wear.
Directly from the owners manual https://cdn.dealereprocess.org/cdn/servicemanuals/buick/2001-lesabre.pdf
The maintenance schedule you posted was for short tripped/city driven vehicles....frequent 5-10 miles in cold weather, to go along with the usual other conditions (extensive idling, dusty roads, towing, stop and go traffic). Otherwise it is recommended for 7,500 mile intervals. I worked on these vehicles for ten years, 7,500 was the oil change interval in our fleet...the 3.8 liter almost never suffered engine problems and easily handled very high mileage. The only issue I can even remember with these vehicles was a design flaw with the EGR tube running through the intake manifold, that would occasionally cause a coolant leak into the manifold. A TSB and redesigned gasket took care of that.1) OP made no mention of having an OLM.
OP has a 65,000 mile car. Almost a given that a 20 year old 65k car wasn't a highway cruiser.The maintenance schedule you posted was for short tripped/city driven vehicles....frequent 5-10 miles in cold weather, to go along with the usual other conditions (extensive idling, dusty roads, towing, stop and go traffic). Otherwise it is recommended for 7,500 mile intervals.
That sounds like hearsay. I'd like to see some irrefutable proof of this claim.There are reports that some engines consume GTL based oils (Shell, Quaker state, Pennzoil). Simply choose a different brand.
Do you recognize yourself somewhere in this movie?OP has a 65,000 mile car. Almost a given that a 20 year old 65k car wasn't a highway cruiser.
That may be more related to the weight of the base oil not the type of the base oil.I read it here often. Hersay, of course.
But: There was one thread in the german Honda S2000 community, where the members posted wich oil they used and compared the oil consumption. The "Winner" was the only member wich used Shell Helix Ultra, he reported the highest oil Consumption. Up to 2.5 Quarts at 600 Miles on the racetrack and 1 Quart at 600 Miles at road use.
My Honda S2000 also had a very high oil Consumption with the Shell Helix Ultra. I cut it in half as i switched to a different brand.
So, what i wrote is based partly on what i read in Internet forums - like many others here - and partly own expirience.
Base oil, not viscosity of the final product, lol.5w-40 as allways.... And every member in the German Honda S2000 Community uses 5w-40.
If you dont belive me, fine.
I think it´s a pitty because these shell GTL oils are really good and cheap.
To add to what @OVERKILL already said: if you use a motor oil blended with thin base oils in the environment you describe, you will get oil consumption. It doesn't have to be GTL. It can be blended with thin PAO, thin Group III, or a mix. They're all hydrocarbons, they all burn eventually. Add some fuel dilution to the mix and you accelerate that.5w-40 as allways.... And every member in the German Honda S2000 Community uses 5w-40.
This should be a sticky at the top of the page.Base oil, not viscosity of the final product, lol.
It could use a lot of 4cSt base oil in the blend, which may be more prone to consumption.
