Does the 250,000 mile quaker state warranty still apply if you use their "slick" oil?
I don't know what your problem is, but just because they sell Slick 50 doesn't mean that they are selling an inferior oil. Just by looking at UOAs and VOAs Pennzoil is one of the better oils out there. Plus your analogy makes no sense. It's like saying I don't like Fram oil filters so I won't buy its air filters either.quote:
Originally posted by LarryL:
I think it would be better stated that if you want an oil up to the standards of Slick 50 you can stay in the same family of products including QS. Don't exclude QS or Penzoil from you list. If you use Slick 50 then they have you covered for you oil. QS can be consided every bit as good as Slick 50.
Not only that, but we have no real evidence, backed up by UOA, that Slick 50 is actually a bad product. It may have been in years past, but I don't think it is the same product that it used to be.quote:
Here, Larry, let me help you out with applying this guilty-by-association principle!quote:
Where I get my oil changed.quote:
Originally posted by dave1251:
Johnson994 what do you mean by your lube shop?
Originally posted by farrarfan1:
[QB] Yep, Quaker state is obviously a terrible oil. Look at these disastrous UOA's.![]()
Farrarfan1: After reading the UOA's I see you
were being sarcastic. As I stated before an ex-coworker of mine had nearly 300k on an 89' Corolla using QS dino almost exclusively.(He may still have the car with 400K for all I know).
I wouldn't hesitate to use QS at all.Yes I was. Quaker State did just fine in the few most recent UOA's I posted from this board. It amuses me when someone comes on here and flat out states they wouldn't recomend "X" brand oil under any circumstances in any engine anywhere in the world based on no factual basis whatsoever.My facts are proven when I worked in a shop that when they changed the oil Quaker State they used all of a sudden timing chains are braking and camshafts going bad. If you don't believe it fine then use Quaker State then!
My facts are proven
I wouldn't hesitate to use QS at all.Yes I was. Quaker State did just fine in the few most recent UOA's I posted from this board. It amuses me when someone comes on here and flat out states they wouldn't recomend "X" brand oil under any circumstances in any engine anywhere in the world based on no factual basis whatsoever.My facts are proven when I worked in a shop that when they changed the oil Quaker State they used all of a sudden timing chains are braking and camshafts going bad. If you don't believe it fine then use Quaker State then!You lost me here. Are you saying that the shop you worked in switched to Quaker State and then customers began losing cams and timing belts? If so did they have the oil tested to make sure it was actually Quaker State of the proper viscosity and correct API and ILSAC ratings and if so did your shop contact Shell/Quaker State and work with them to find a soulution? Did anyone determine that the cams and timing belts breaking where actually oil related failures at all? I don't use QS/Pennzoil but one of our regulars here works for Pennzoil and I defer to his opinion without question when it comes to those products.They currently meet the latest API/Ilsac ratings and have shown satisfactory UOA's.
I’ll give this one more shot!quote:
So if you use QS or Penzoil and believe the corporation is a quality orientated operation then you should use Slick 50.
Wow! Self-righteous. If I had to sell Slick 50, I'd find something else to do. That's not self-righteous. Marketing runs business. The technical aspects often get trampled. If not, why this forum to explore what marketing does not tell us.quote:
I love the self-righteous attitudes toward marginal brands. Ask yourself, if *I* were suddenly charged with making a product profitable, even a defunct name brand like Slick 50, what decision about packaging and reformulating be appropriate? Even better, let's say QS or SOPUS GAVE you the Slick 50 name and you had to make a living and feed your family? I suppose Larry would just file it away and do the World a favour. [Roll Eyes]
