I took the El Camino out last night in 45 degree weather and she was making a popping sound until the car got totally warmed up.
The car did not do this last week when it was 72 degrees out.
I am going to have to start this car up cold and watch too see how fast the choke opens up and spray some carb cleaner to see if there are any vacuum leaks.
One guy told me that I could have an intake manifold vacuum leak and that when the car gets warm the metal expands and there is no leak.
Maybe I need to check my timing, but if it were off wouldn't the car be running bad all of the time.
My spark plugs need to be gapped at .045 and they might have been gapped to .050, I do not know if this would make a difference.
I believe my ignition coil is fine because the car starts perfectly whether the car is hot or cold.
Maybe I have the idle mixture screws too rich, which is letting more fuel into the combustion chambers and it is not getting burned.
A mechanic at the speed shop thinks its timing or my plugs are gapped to high meaning when cold the plugs are not firing right.
The other thought is that maybe the exhaust crossover in my intake manifold that brings heat to the carburetor is stopped up, obviously when the car is cold it needs the heat for a better burn as opposed to when it is warmer outside.
I am going to do the mixture screws again and turn them all the way in and then 1-1/2 turn out or maybe 2 turns out, I checked them last night and they are at 4.5 turns out.
I do not think I have a burnt valve or a weak spring in the cylinder heads because the car runs great when she is warmed up.
If I cannot figure it out I may get my friend who is pretty good with working on engines.
