Q? About My Next Oil Change
Tri Cities, TN
I'm at 4500 miles on this OCI in my civic. For the next change I'm wanting to try a 0w-20 such as Mobil 1. But I also have 1 qt of Pennzoil Ultra, 1 qt of Mobil Super 5000, & 1 qt of Mobil 1 (all 5w-20) left over from previous changes. Sump capacity is about 4 quarts. Can I make a good blend out of what I have or should I go ahead and get a 0w-20?
+1...
Mix/match with any of those oils and you'll have no problems. A 0W shouldn't have a tremendous impact with winter temps in TN - at least I wouldn't think so.
Since you'll need a 4th, throw in the 0W
Play with this calculator to see what you come up with as a mix:
Calc
Originally Posted By: Finz
Play with tjis calculator to see what you come up with as a mix:
Calc
I'm not the OP but thank you for posting this. Very useful!
