Originally Posted By: jdawg89
Ok, so I will consider changing every other...and imo the filter is oversized for the van and undersize for the truck lol. (They take the same filter) and I'm just parinoid about dry starts. Even if I don't change the filter I still remove the coil wire and crank it untill I get my pressure up. And I fill the filter in the van because its easy to get on. On the other hand the truck is sorta a pain....
You are worrying way to much about a "dry start". If you run you vehicle right before an oil change there will still be a layer of oil coating the internal parts and there is still some oil left in your engine. Some engines have as much as 1qt of residual oil. Change the oil and the filter and love your engine. Putting fresh oil through a used up oil filter just does not cut it for a dry start... now if your using a 15k filter for a 3-5k oci, then I could see reusing a filter but those usually have synthetic media.
