Purolator L24458 Equivalents
Lake Forest, CA
What are Purolator L24458 equivalents in size, relief valve pressure and threads ? Are these Wix similar in sizes: 51356, 51568 and 51344 ? How about Motorcraft and Bosch, do they have equivalent filter to L24458 ?
Part Number: 51568
UPC Number: 765809515680
Principal Application: Komatsu Equipment, Yanmar Engines
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.072
Outer Diameter Top: 3.234
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 320
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.148
Part Number: 51344
UPC Number: 765809513440
Principal Application: Various Equipment w/ Isuzu & Yanmar Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.069
Outer Diameter Top: 3.242
By-Pass Valve Setting-PSI: 8-11
Beta Ratio: 2/20=22/40
Burst Pressure-PSI: 360
Gasket Diameters
Attached 2.490 2.200 0.148
Part Number: 51356
UPC Number: 765809513563
Principal Application: Acura (02-09), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-09), Infiniti/Nissan (96-09), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-09), Saturn (04-07), Outboard Marine Engines, Various HD Equip.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Outer Diameter Top: 2.685
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 363
Gasket Diameters
Attached 2.475 2.173 0.233
It looks like they're discontinuing that one. Taking the number to the Fram site, then checking the cross-references brought up by the 2 Fram equivalents (PH3593A is the 4" version & PH5046 is 5" long), you'll find a number of filters that'll work.
Motorcraft and Bosch don't , but you can use an L-20073 on most cars without any leaks.
I have used the L-20073 on Hondas that normally use the L-14459 or L-24458 without any problems or leaks.
My local Honda dealer doesn't carry 15400-PCX-004 filter for S2000, they only have smaller filter for all Honda cars. I'll check L-20073 specs, is it longer than L-14459 ?
Some crazy guy (wait! that's me
) put a different oil filter stud on my car (which used to take an M20x1.5 threaded filter like the L14459) that had metric threads on one side, and standard threads on the other (3/4x16). This allows me to run the Motorcraft FL-400S (or any other 3/4x16 threaded filter that fits) on my Subaru. The part is Mopar part# 3300-4125 (around $8). You can follow the whole thread here
Dave
