Originally Posted By: abycat
Originally Posted By: Triple_Se7en
Originally Posted By: crazyoildude
personally i will take flow over filtration any time
What filter brand / model do you prefer?
He does have a good point. If any time your oil flow is interrupted you will have major wear in a short period of time. if the oil pressure or flow is light at the far end of the engine and its not getting proper lubrication there will be damage from it or at least very accelerated wear.
But a filter cant get out the abrasive silicon in the oil and cant filter out iron and other metals that cause wear or even water or fuel isnt filtered just basically chunks and grains are filtered.
Using a good qual filter that is rated for your application and changing it at the proper time seems to be the best bet.
But this would never happen,,,flow wouldn't be hampered because of the bypass valve,worse case it would see plenty of dirty oil.
