Is it my imagination, or is there a torn pleat on the last 2 pictures (Bosch) on the left side, just below the crimp? That metal crimp design has GOT TO GO!
The pleat nearest the crimp on the Classic does not appear to have been glued in a straight line.
Clearly the oil pressure is making the pleats that have the largest gaps to the adjacent pleats bend. But the lack of a V shape is preventing them from tearing like others.
Here is a close up of his filter pic. Yep, it's a tear, just like the others.
It is a good reminder to people when you cut open a filter look very carefully for tears. They can be easy to miss if you don't look very closely (I almost missed the tears that I reported).
wait, if the oil pressure goes up making the pleats create gaps.. shouldnt the bypass kick in?
I know you didnt say oil pressure go up.. but if oil pressure caused this it would be most likly b.c if to much pressure and you would think the bypass would kick in.
Bypass probably is kicking in-but not quickly enough, and repeated pushing of the too-wide pleats & weak-[CENSORED] media on the metal crimped seamed Puro Classic & Bosch filters are tearing them. Worst thing is, I've probably got 20 of these in my stash that are too junky to use.
