Puralator L30001
NY
I purchased a Purolator L30001 oil filter instead of the FL1A Motorcraft which was out of stock .
Are these similar in durability ?
All the Motorcrafts have silicon anti-drain valves. If you got the Purolator classic then it will be a nitrile anti-drain. The Pureone is silicon. That probally being the largest difference.
Thanks . It is a Purolator Classic .I plan on roughly a 6 month oci and have had good luck with the FL1A . I guess it will be almost the same . I am thinking on switching to the Pureone now .
I'm pretty sure the Motorcraft FL1A does not have a silicone ADBV. It is nitrile. I would describe the Purolator L30001, which is the classic design with a nitrile ADBV also, as very similar to the FL1A. Both very good for standard OCIs, but not extended.
I believe only the Motorcraft filters that end in "S" have the silicone ADBV, like the FL-820S. The last FL1-A I bought, last year, has a black ADBV that does not look like silicone. Not a big deal, but I do think silicone is better in the winter and for longer OCIs.
I'm thinking AE may be correct here. If it doesn't have the S at the end, it's likely the black nitrile. The biggest difference then might be if the FL1-A has thread end bypass, as many, but not all MC's do. Some folks prefer thread end, to me it not a big deal either way.
The L30001 should be just fine for a ~5k/6month OCI, and 97.5% efficient ain't too shabby. Use with confidence.
It is nitrile. I use the FL1A regularly, and they are nitrile. The FL1A also has the thread end bypass.
In general I think the Motorcraft filters are among the best for "bang for the buck" if you can get the size you need at WalMart for less than $4. Solid construction, though as we have discussed on here before, an uncertain efficiency rating.
x2 on that
