Originally Posted By: MaximaGuy
Determine where the low pressure hose (3/8" smaller hose connected to the PS reservoir) as it makes to the front of the vehicle. Usually the line goes towards the front frame it could be different in your vehicle,
a) Raise the front of the vehicle above ground.
b) Disconnect it and drain into a pan and stick a pencil into it and plug it tight.
c) Attached a 3/8" hose to the other end and point to a gallon jug.
d) Put vehicle in ACC with the vehicle raised and do steering locks to push all fluid out of pump and rack.
e) Now refill reservoir with fresh fluid and keep doing steering locks as new fluid makes its way into the rack and pump.
f) Once there is fluid coming out of the disconnect end, stop, remove hose and reconnect return line back.
g) Start vehicle and do steering locks to push air off the system, top it off and bring the vehicle down
The capacity is usually a Quart and use PS fluid.
Do everything this guy says; it works very well, the key is having the front wheels off the ground and a helper turn the wheels lock to lock. While you're at it, take it one step further...Repeat the whole process once, and your PS fluid in the reservoir will end up looking like the stuff in the new container. And once you've got the car up, the line disconnected, etc., it doesn't take all that much longer to simply repeat the process once.
It's not hard, and your helper can listen to the radio and be comfy. And I daresay it IS much faster and better than the turkey baster method that must be done ad infinitum.
edit: You DON'T need to start the engine to get all the old fluid out; just turn the wheels lock to lock. I'm not sure I'd even like the idea of starting the motor with the system drained. Excellent way to introduce tons of air and run the pump dry.
