From reading this forum for the last few years, I gather that these are the most commonly agreed/perceived benefits of synthetic oils:
1) Improved low temperature flow
2) More resistant to oil breakdown at extreme oil temperatures (305F or higher)
3) Improved viscosity retention
4) More linear viscosity profile to benefit VVT systems, as some of these systems use engine oil as a hydraulic system
5) Improved film strength
6) Reduced engine deposit build-up
7) Increased service intervals
GM recommends synthetic oil in cold climates. They also factory fill several of their track ready models with synthetic oil to eliminate the need for an oil cooler, and improve engine protection (due to reduction in oil breakdown) at oil temperatures above 305F. Certain 3.6L VVT-equipped V6 engines and VVT equipped Northstar V8 engines also carry a synthetic oil recommendation as the VVT systems prefer the improved cold temperature properties of synthetic oil, especially the more linear viscosity profile overall. Hence, I’m in full agreement with benefits #1, #2, and #4 of synthetic oil.
Some synthetic oil users use the product for the purpose of improved viscosity retention and improved film strength. Yet, I do not see significantly improved UOA results resulting from the usage of synthetic oil, considering normal daily driving conditions. Thus, I’m skeptical of the claimed benefits #3 and #5 as justification of using synthetic oil.
Lastly, I come to the most common reasons why some use synthetic oil (when it isn’t recommended by the OEM): reduced engine deposits (#6) and increased service intervals (#7). Repeatedly, I’ve yet to see any solid evidence indicating the reduction of engine deposits by using synthetic oil, compared to using conventional oil changed at recommended intervals. Note: this only applies to applications where synthetic is not required. So, with all this talk about synthetic oil keeping your engine cleaner, prove it. I’m not convinced, yet…
In addition, why is the extended service interval capability automatically assumed when using synthetic oil??? From what I gather, engine oil is replaced for a variety of reasons: contamination, additive depletion, prolonged exposure to extremely high oil temperatures, etc. But why does the usage of synthetic oil allow one to go much longer between oil changes? Won’t synthetic oil be subject to the same level of contamination as other oils?
GM calibrates their oil life monitor with the same upper limit for vehicles equipped with or without synthetic oil. All SM/GF-4 rated oils have the same limits on the main additive treat levels. Some state that the higher starting TBN on synthetic oils allow for longer service intervals. But this is changing. Look at the new Amsoil 5w40. It is rated for 502.00/505.01 applications. The starting TBN is no higher than that of most conventional oils, if not lower. Yet, the recommended service interval for 502.00/505.01 applications can sometimes be in excess of 10k miles. Thus, perhaps TBN isn’t as hyped up as some claim it to be. And the many UOAs users do on this forum does not indicate the amount of active additive available.
My point is that I’m not fully convinced that synthetic oils provide some of its perceived benefits, especially to the average driver. I’m especially interested in what some of you have to say about synthetic oils and extended service intervals. I’m not convinced of some of the benefits synthetic oils claim to have. Now prove to me that synthetic oil can really last drastically longer, keep my engine significantly cleaner, that the improved film strength can significantly reduce engine wear under normal driving, and the improved viscosity retention can make a difference.
TIA.
TIA.
