If all I want to do is find out which oil would be thinnest on the coldest day of the year, is my only option to use the Pour Point and assume that the oil with the lowest Pour Point will be thinnest at winter temps (say around 0*F) ?
I want to compare readily-available (non boutique) 0W-x oils to find the thinnest. I may not actually run it, more of a quest for knowledge at this point....
Thanks!
Thanks!
